Old 06-01-2009, 02:09 PM   #1
album covers "tiled" on a concrete floor? is it possible?
hello. i have recently purchased a home, it is a tri-level, and my wife and i are converting the lower level of the home into a bar area.
i pulled up the carpet, and it is smooth concrete beneath.
the look i am hoping to achieve is that of the floor completely tiled in old album covers. i am a diy'er, but don't have much experience in this particular field.
what i am thinking of doing is simply etching/cleaning the concrete floor, and then simply gluing the album covers (all the same thickness) to the concrete, and then covering it with an epoxy.
what i'm unsure of is how well the epoxy will hold up on a floor through the years, and also if the epoxy will adhere well to the album covers.
if anyone has ever heard of this, or has any input, or any other easier/cheaper/or more durable ideas, please, chime in!
thanks.
brian williams
brian williams is offline   Reply With Quote
Old 06-05-2009, 09:33 PM   #2
That sounds cool as hell.
I've seen wood with epoxy poured to encapsulate paper things on wood. That holds up under abuse for years.
The cool thing about pouring epoxy is that it is self leveling. A trick I used was to run a hair dryer over it to release any air bubbles.
There is a 'work time' and then a cure time. This might vary depending on the product. Depending on the size of your floor you might have to consider sections?
My concerns would be the cost to epoxy a floor thick enough to bury the covers and then some. Also what glue would affix the paper to concrete.
It might be worth it to grab a bag of concrete and mix a test slab and experiment before you commit time and money to a floor. You can turn those into garden stepping stones.
I does sound cool.
Good luck.
drillbit is offline   Reply With Quote
Old 06-05-2009, 10:52 PM   #3
Xtreme DIY'r
The floor would also need to be sealed so that moisturecould not effect the album covers
Anything smooth enough to see thru I think would be a hazard when wet
Better idea for a bar top/tables I think
Old 06-08-2009, 10:43 AM   #4
gravity always wins
Better also test to be sure that latent vapor pressure in the concrete doesn't lift your epoxy after it's on and cured. Epoxy doesn't allow vapor through. Anything trapped will build pressure until it blows the epoxy off of the surface.
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 36 08-05-2012 11:43 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 09:21 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
