Old 04-01-2009, 01:27 PM   #1
after tile installation? sealant?
so i have my tiles done and grouted and cleaned. dont i have to seal something? seal the grout or the whole floor? can someone explain?
fabian is offline   Reply With Quote
Old 04-01-2009, 02:43 PM   #2
Remodeling Contractor
Depends on the tile. Ceramic or porcelain seal the grout only. Natural stone, travertine and slate.. seal everything. Wait for 72 hours before sealing.
Old 04-01-2009, 03:02 PM   #3
yeah i have percelain. what kind of grout sealant? clear? home center stuff?
Old 04-01-2009, 03:14 PM   #4
Home center stuff is poor quality. Almost as good as water.
I would use Miracle's 511 Impregnator
Test an area first. Some porcelains (cheap stuff) are not as good as one would expect and may absorb some of the sealer and look different. To avoid this using a damp mop, wet the tile slightly first.
Old 04-01-2009, 03:35 PM   #5
but im only sealing the grout not the tiles right? so use a mop on the grout lines?
Old 04-01-2009, 04:12 PM   #6
Nothing wrong with Home center sealer, depends on the brand, think Lowes still carries Aquamix and is a very good sealer.
Miracle is good as is Aquamix, Stonetech, SCI and others.
Don't mop anything, just get a grout applicator bottle and use that, it's a small plastic bottle with a brush or wheel on the tip, fill the bottle and squeeze it as you go and just brush it on the grout, keep a paper towel with you and wipe any excess that might get on the tile, you'll be fine.
R&D Tile is offline   Reply With Quote
Old 04-01-2009, 06:51 PM   #7
Yes you are applying to the grout only. The suggestion to wet the porcelain was as a protection against the sealer effecting the tile. It should not. but nothing is 100% when I do not know your tile. Aquamix is also good, not available here at HD.
Old 04-01-2009, 09:18 PM   #8
Tileman-Manufacturers rep
Nice try there Bob. You wet before you paint....not before you seal, everyone knows that.....?
Generally you only need to seal the grout. However, both glazed ceramic and all porcelain can also be sealed to fill microscopic pores. You will think none is being absorbed, but a small amount is.
If you use a high quality sealer such as 511, it tells you right in the data to apply on the tiles too. In addition to filling the pores, 511 on glazed tiles make them LESS slippery. HUH? YES, Less slippery.
Make sure you follow directions and wipe off all excess material from the tiles.
Jaz
Tile 4 You Inc. Troy, MI
KERDI Shower Expert...DITRA Installs
Old 04-01-2009, 09:40 PM   #9
Jaz
Did I say some of this incorrectly. I am wetting so as to not seal only part of the tiles since these tiles most likely do not need sealing. Only sealing the grout, and I said wet the tile and seal the grout. Which part do you see as incorrect?
Old 04-02-2009, 05:55 AM   #10
How are you going to wet the tile with a mop and keep the grout dry for the sealer?
Water and sealer don't go well together when applied.
No need to wet anything and unless they are unglazed porcelain, I would just seal the grout as I stated.
Old 04-02-2009, 10:59 AM   #11
Bob,
We are not here to teach the "teacher". We are supposed to give good advice to the nice people that come here who are trying to save a few $$$. If you don't know why you do not wet the tile before sealing the grout, I can't help you.
However, I suggest doing lots of reading on the subject of "tile installations & care", so that in the future everyone will have confidence in your advise. It's real easy these days with these 'puter things we got here.
Jaz
Old 04-02-2009, 01:19 PM   #12
I never encountered this problem. I know that 90% or porcelain tiles will have no effect from the sealer. I have read at Mr. Bryne's forum that some will discolor and wetting it first was a way to avoid this. I do not know what this OP's tile is and was trying to offer overly careful advise. R & D set me straight. I was looking at my 18 X 18 tiles on this floor as I wrote it. Missing the grout was not a problem. Glad you set me straight.
More On This Topic
Tile floors make great surfaces in basement settings. Whatever type tile you chose, you can lay your own tile floor and easily keep it looking good. One of the processes to keeping a good-looking tile floor is sealing the grout. It's an easy step to do... Read More »
Hi! This is Steven from Keilholz Flooring on behalf of Expertvillage.com. In this segment, I am going to show you how to clean the grout. In our last segment, I used an acrylic grout versus a sandy or a non sandy grout. Typically we would use a sponge... Read More »
Tiled counter tops are very classy looking until the grout joints get stained or begin to loosen. You can save the expense of replacing the counter with just a little work. Re-grout the tile on your counter by following the steps and tips below. Read More »
How to Seal Tile
How to Seal Tile by eHow.com
Most tiles used in homes are glazed, and the glazing process creates a seal. But if you use porous materials, such as terra cotta, marble or slate, you will need to seal the tile to keep the surface looking good and to prevent stains on that surface you... Read More »
Today we’re going to be re-grouting the tile around the window in the bathtub. Once your grout has set out for about five to eight minutes, you get yourself a grout trowel, which is just spongy so you can apply the grout. And you just scoop some... Read More »
Re-tiling a bathtub surround BillyB44 Remodeling 37 05-13-2009 08:05 PM
Granite Tile Discoloration during installation russ2008 Flooring 13 04-30-2009 07:37 AM
Tile installation question pjpjpjpj Carpentry 7 09-21-2008 12:29 PM
Subway tile installation bigboyjoel Flooring 3 08-02-2007 08:15 AM
Ceramic Tile Backsplash Installation DK75 General Discussion 4 11-01-2006 08:56 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
