Affordable %100 Solids Epoxy - Flooring - DIY Chatroom Home Improvement Forum
Old 04-09-2009, 07:58 PM   #1
Anyone here have any experience/knowledge of Krylon Dura-Top %100 solids floor epoxy? It appears to be the best value I've found at $175 resin + $50 hardener for a whopping total of "5 Gallons" of product. Available through Global Industrial, Grainger and others. If not any other recommendations would be appreciated. I have 750 square ft of floor (3 car garage) to cover.
kygarageguy is offline   Reply With Quote
Old 04-10-2009, 08:48 AM   #2
ccarlisle's Avatar
Since we don't know you at all, define for us exactly what 'affordable' and 'best value' mean exactly to you...for example, you have a three car garage to cover. Is $225 five or ten dollars beyond "affordable"?
How long is a piece of string...
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 04-11-2009, 07:46 AM   #3
never heard of it,,, may be a repackag'd product from another outfit, relabel'd, or chink import,,, our stuff's $431 {color'd & uv-resistant ) for 5g, another's $315 for 5g, & $347 for another type - all depends what qualities you need for the item you're doing,,, on the other hand, we also use aliphatic urethane over the top to protect the epoxy - that's another $349 for 5g,,, things more clear, now ? ? ?
your ' best value ' sounds like sub-standard stuff to us but our standards're higher,,, you're excus'd 'cause you're a h/o-diy'er.
yesitsconcrete is offline   Reply With Quote
Epoxy Garage Flooring boba7523 Flooring 37 02-28-2009 10:24 PM
Bathtub Chipping In Bottom llg871 Remodeling 3 12-18-2008 12:32 AM
Painted Tub With Epoxy, Didn't work.. Need your advice diyfan902 Painting 1 03-11-2007 04:55 PM
