Advise On Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 07-17-2011, 02:49 AM   #1
advise on flooring
hi all,
i am a new home buyer faced with the task of sorting out the lounge/ dining room flooring. The previous owner had parquet flooring laid down (i think oak), which has now gone chipped and jaded. the adhesive has come loose in places, making the flooring creak as i walk. some of the panels have also come off in places.
my question is what would be the best way to go from here. repair individual tiles or replace the parquet flooring? my end point was to have the the lounge carpetted. in this case does the underflooring have to be replaced or are there any cheaper alternatives.
any advise will be most welcome.
thanks
salil
salil.karkhanis is offline   Reply With Quote
Old 07-17-2011, 05:35 AM   #2
DIY staff
Rewards Points: 7,174
You will be smart to remove the old parquet---assess the condition of the underlaynent and sub floor.
Then decide what you want to do.
Old 07-17-2011, 10:09 AM   #3
advise on flooring
thanks for that.
when you usually lay a carpet, is it normally over the subfloor or over a wooden flooring. i mean would i have to have a wooden flooring layed before i think of laying the carpet?
looking forward to your reply.
thanks
salil
Old 07-17-2011, 10:11 AM   #4
normally they lay the pad over the subfloor and carpet over that.
Old 07-17-2011, 01:33 PM   #5
thanks
Old 07-17-2011, 02:13 PM   #6
DIY staff
Get any messy work done before the carpet--that means --wood,tile finish and trim first--
Carpet is last.
Old 07-18-2011, 01:03 PM   #7
Hello, I want to change from carpet to wood floor. Concrete is under the carpet. What is my best choice? No laminate please.
sharonlee is offline   Reply With Quote
Old 07-19-2011, 11:17 AM   #8
tile or engineered flooring
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 4 06-07-2017 06:24 PM
asbestos in our ripped up flooring?? 6fthook Flooring 16 07-29-2011 11:06 PM
Strange engineered wood flooring install in Philippines (pics) Flt_Simulation Flooring 7 10-05-2009 09:00 AM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
no glue, no nails wood flooring - little help? reds_21 Flooring 2 02-13-2009 11:32 AM
