Advice Needed On Installation Of BELLAWOOD 5/16" X 2-1/4" Select Brazilian Walnut - Flooring - DIY Chatroom Home Improvement Forum
Old 05-26-2010, 11:56 AM   #1
Advice needed on installation of BELLAWOOD 5/16" x 2-1/4" Select Brazilian Walnut
I am looking for any advice or insight on this project. I am a complete newb, first time homeowner...
I am installing BELLAWOOD 5/16" x 2-1/4" Select Brazilian Walnut Prefinished Select LINK: http://www.bellawood.com/catalog/pro...bCategoryId=71 on this subfloor:
It's tough to tell, but the subfloor is fairly even and flat. I plan on laying 1/4" birch underlayment on top of the subfloor.
I plan on using Bostik's Best Adhesive. Do I need to use staples/nails as well? Or will the glue suffice?
lifterpuller is offline   Reply With Quote
Old 05-27-2010, 03:06 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 14
Bellawood doesn't have a good reputation among installers.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 05-30-2010, 02:30 AM   #3
yep bella seems to be cheap stuff , I would scrape the floor <<< Unless it's just impossible to clean , Then nail it down , It looks like the residue of glue down carpet pad , Some time that can be hard to remove , You can sharpen the floor scraper on one side only , Then lay it on the side that doesn;t dig , Then use sort of a 45% angle scrape it the direction of the grain , This will allow sort of a cutting scrape motion , tacomahardwoodfloors.com
tacomahardwood. is offline   Reply With Quote
Entry Door installation... Advice needed! mburgess44 General DIY Discussions 19 09-12-2009 08:46 PM
