Advice - Electric Radiant Floor ! - Flooring - DIY Chatroom Home Improvement Forum
Old 04-02-2008, 04:51 AM   #1
I'm looking to install electric radiant heating wires in our rehabbed bathroom and would like to have a 7-day programmable control. Iíve priced the 7 day controls at about $150 on Houseneeds.com and was looking to see if it is possible to use a programmable HVAC temperature control instead? Any feedback would be greatly appreciated.
sandy2982 is offline   Reply With Quote
Old 04-02-2008, 07:18 AM   #2
Rewards Points: 896
Typical HVAC thermostats don't control line voltage directy. You'd need a separate contactor to make it work. In addition, these thermostats adjust based on the air temperature.
A thermostat specifically for electric radiant has a probe which adjusts based on the floor temperature. Also includes the required GFCI protection.
LawnGuyLandSparky is online now   Reply With Quote
Old 04-15-2008, 03:07 AM   #3
Hi LawnGuy !! That's news to me.. Thanks for sharing ! Now I guess I would pick the right stuff that I need...
radiant floor heat thermostat kornbln Electrical 5 03-27-2008 01:45 PM
porcelain tile over electric radiant heat aak3 Flooring 7 01-30-2008 09:33 AM
Electric radiant heat in the garage art2670 Flooring 4 01-26-2008 09:58 AM
elec. floor radiant or hydronic ??? James Con HVAC 1 10-16-2007 07:36 AM
bathroom floor tile job advice needed dbrew Flooring 14 01-23-2007 08:03 PM
