Advice On Cork Flooring In Bath & Kitchen. - Flooring - DIY Chatroom Home Improvement Forum
Old 01-20-2012, 04:44 PM   #1
Advice on cork flooring in bath & kitchen.
I am considering cork floors for my kitchen and bath; 12" x 12" x 5/16" glued pre- finished tiles with two top coats of sealer (per the manufactures recommendations). Is this advisable? If it is what underlayment would be appropriate for a OSB subfloor and how should it be installed?
J.KevinHarvey is offline   Reply With Quote
Old 01-20-2012, 05:20 PM   #2
MarginallyQualified
Rewards Points: 2,464
glue down tiles in a kitchen or bath is at the "better not" end of the scale
think NON pourous
Old 01-20-2012, 05:39 PM   #3
mike owes me $53 dollars
Tech Dawg's Avatar
Maybe consider a Ceramic tile installation for your bathroom
I've seen some nightmarish looking, rotten wood floors in bathrooms...
Todd
www.aloneeagle.com
Tech Dawg is offline   Reply With Quote
Old 01-20-2012, 07:07 PM   #4
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 38
Cork is a bad idea in moist areas.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 01-21-2012, 05:32 PM   #5
We have had lots of customers put cork in the kitchen with 2 extra coats of sealant and the have not had any problem. Remember though if your flooring gets flooded (dishwasher breaks) it will ruin any laminate or cork floating floor because the center is made with HDF which will bloat when saturated. Tile would obviously the best choice if you were concerned about this.
For the bathroom I would recommend a glue down cork because it does not have that center HDF.
If you go back to all the mid century modern architects all of them used cork glue down tiles in their homes. With this said, the final decision is yours and you should definitely read everything you can and hear all sides of the discussions.
John
APC Cork is offline   Reply With Quote
The Following User Says Thank You to APC Cork For This Useful Post:
Tech Dawg (01-21-2012)
Old 01-21-2012, 05:39 PM   #6
Tech Dawg's Avatar
John
Thanks for the info
Todd
www.aloneeagle.com
Venting Bath and Kitchen fans jbeaulieu HVAC 1 04-29-2011 11:27 AM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 07:38 AM
Project floor plan for Kitchen and Bath Snav Kitchen & Bath Remodeling 0 01-25-2010 11:51 AM
Adding a bath and Kitchen in the game room cprao Remodeling 4 12-31-2009 10:43 AM
wood laminate flooring in kitchen kjacobson Flooring 11 02-17-2007 03:20 PM
