Adhesives For Wood Floor Transitions On Slab - Flooring - DIY Chatroom Home Improvement Forum
Old 07-15-2010, 05:19 PM   #1
adhesives for wood floor transitions on slab
Hey all...
I installed bruce floating cherry... like it as much as expected knowing my slab wasnt perfect... the issue I am having is with the transitions... the part that glues to the floor wasnt quite long enough I think due to purchasing the premium underlayment, or it just wasnt right from design forward... anyway,... I used a sliver of plywood as a height filler and glued them in.,..
well in high traffic areas they arent staying down... I have tried liquid nails, as well as power grab. these glues both dry hard. I am thinking with the stepping on, and flex involved, maybe something that doesnt dry super hard would be right? or just MORE glue to give it a more secure setting??
has anyone had this issue and solved it?
thanks
carsonsig is offline   Reply With Quote
Pouring Patio Slab and Post Footings Question average_male Building & Construction 22 04-04-2016 01:13 PM
engineer wood floor @ uneven Slab on grade gtimk4 Flooring 0 03-21-2010 07:29 PM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 01:23 PM
New Basement with Moisture Problems from Slab fasteddie Flooring 41 01-14-2010 03:01 AM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 01:50 PM
