Adhesive For Transition Moldings - Flooring - DIY Chatroom Home Improvement Forum
Old 08-19-2009, 09:46 AM   #1
Rewards Points: 51
Adhesive for transition moldings
I need to install T-molding between a new hardwood floor and existing tile floor. (I have some other transitions to install, but this is the most tricky one) The literature I've found about installing transitions say to use construction adhesive to attach the T-molding to the tile, leaving an expansion gap on the hardwood side. Since I did a nail-down application for the wood floor, and not glue-down, I have no adhesive, and don't want to buy a big bucket of it just for the transitions.
At Home Depot yesterday, I found several products in the glue section (DAP, GE Silicone II, etc), that list "moldings" as applications, but I'm unsure if they only mean wall moldings, or floor moldings too. Mostly these appear to be labeled "All-purpose", and say they can be used for wood, tile, etc. Does anyone have advice for what I should use? Thanks
preciouschristy is offline   Reply With Quote
Old 08-19-2009, 03:22 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
That's nuts! If you glue one to the other you would want to glue the two more similar products together because of different rates of expansion and contraction between the tile and the other components. Glue the "T" to the wood and let it ride the surface of the tile without any glue.
Actually most "T" moldings are installed in a metal channel that is fastened to the subfloor and the "T" simply snaps into the metal.
As far as the proper adhesive to use it would be "contact adhesive" applied to both surfaces (to be glued) and allow it to air-dry for a few minutes until both are tacky. Press them together and watch it hold.
XXX
Old 08-19-2009, 09:36 PM   #3
Rewards Points: 51
I'm getting more confused. None of the websites or books I'd seen mention this "track" you're talking about, but after googling "t-molding track" I find several sites selling t-molding WITH track. Of course, mine didn't come with track.
None of the websites are consistent with each other. Some say to glue it to the tile, others say glue it to "one" of the surfaces, doesn't matter which. Several say to drill pilot holes if I'm going to nail it. If I'm installing it directly to the wood flooring, should I nail it instead of gluing it? I nailed the rest of the floor down.
It's truly annoying that there is an abundance of books, articles and websites (not to mention the directions from the flooring manufacturer) that describe in great detail how to lay the flooring, and almost none that tell you how to install the moldings.
Old 08-20-2009, 08:28 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Sure you can nail it absent the metal channel. They are correct that you MUST first drill pilot holes. Drill the holes, glue it only the the substrate, then drive finish nails to take it home.
THEN, force a little caulk under both sides to close the hairline gap and absorb any movement. Try that.
There is more than one way to skin a cat and getting frustrated over various recommendations that exist in the flooring industry is a waste of energy.
XXX
Old 08-21-2009, 12:44 AM   #5
Rewards Points: 51
Thanks- I'll give it a try
Problems with Omni Grip tile adhesive Blue Flooring 24 05-15-2016 07:37 PM
Granite & Adhesive question cody21 Kitchen & Bath Remodeling 3 07-22-2009 05:11 PM
What type of adhesive should I use to glue down accoustical cork to a concrete floo Fixitgeorge Flooring 2 03-20-2009 07:54 AM
Removing Vinyl Tile Adhesive from Linoleum The Raven Flooring 3 07-22-2008 08:38 PM
ceiling moldings feb Carpentry 4 08-29-2006 08:12 PM
