Adhesive Tongue And Groove Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 01-31-2011, 07:26 PM   #1
Adhesive tongue and groove flooring
What brand of adhesive should I use on engineered flooring; I want a "floating floor" as opposed to gluing the floor to the subfloor. The flooring is not an interlocked floor but has tongue and grooves.
dougf is offline   Reply With Quote
Old 01-31-2011, 09:20 PM   #2
woodman58's Avatar
Unless the manufacturer says that your floor is made to float I would not suggest doing this. If it is made to be floated by glueing the tounge to the groove you can use Tite bond 2. It is a good wood glue that would work well for this installation. Make sure and keep a damp sponge handy to glean the access glue.
woodman58 is offline   Reply With Quote
Flooring for hot tub room with tongue and groove base flooring. tkmiller Flooring 0 10-24-2010 01:21 PM
Replacing tongue in groove with support below odonata3 Flooring 0 10-20-2010 11:40 AM
Install Cabinets directly above Tongue & Groove? caezaar Building & Construction 13 07-06-2010 10:50 PM
1x4 or 1x6 flooring NON tongue and groove easy? c0bra969 Flooring 2 11-17-2009 12:03 AM
The pine tongue and groove has no brenda o General DIY Discussions 38 10-31-2009 01:13 PM
