Old 02-28-2007, 07:47 AM   #1
Adhesive of Slab
As I posted earlier I'm getting ready to ceramic tile a bathroom on a slab. I'm peeling the peel and stick tile up but noticed some sort of adhesive. Is it okay to use thin set over this adhesive? Its not terrible but didn't know if the mortar would adhere to the cement. Also if I need to clean the adhesive, what is the best way to do this?
nsb318 is offline   Reply With Quote
Old 03-01-2007, 12:04 AM   #2
Floorwizard's Avatar
Adhesive of Slab
I do not know the best solvent...
But I would hope you will consider using an anti fracture membrane instead of a direct set onto concrete.
Floorwizard is offline   Reply With Quote
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 01:50 PM
cracks in concrete slab causing home sale to fall though! help! bp13 Building & Construction 14 07-04-2007 01:32 AM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 11:29 AM
