Adhesive Removal From Concrete - Flooring - DIY Chatroom Home Improvement Forum
Old 04-01-2007, 11:09 AM   #1
sod
Adhesive removal from concrete
The home we bought had indoor/outdoor carpet on the front porch. We removed the carpet and now have the glue that was used to lay the carpet left on the concrete. The stuff is like iron and won't come off. Anyone have a suggestion for what would get the old glue off. We would like to either lay tile or have the concrete stained. Thanks for the help.
sod is offline   Reply With Quote
Old 04-01-2007, 11:02 PM   #2
Rewards Points: 77
Rent a low RPM floor machine with a paper pad attachment and some 30 grit paper or a 6in grinder will do the same with care or just scrape, scrape, scrape.
Zero Punch is offline   Reply With Quote
Old 04-02-2007, 05:23 AM   #3
Tile and Paint contractor
use a floor scraper
or a grinder
later,
drink a 6 pack and whine about it
Matt | tile contractor
Charlotte, NC
MattCoops is offline   Reply With Quote
Old 04-02-2007, 08:41 PM   #4
sod
Thanks for the replies
Dang, I was hoping for some miracle product. Sanding, grinding and/or scraping all sound like a pain. Six-pack, nah, I'm thinking at least a case, minimum.
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 09:38 AM
delicate adhesive removal jimmyfunk Flooring 8 01-18-2007 04:22 PM
Adhesive Removal SIE Flooring 4 07-05-2005 10:50 AM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
