Adhesion Of Slate To Concrete - Flooring - DIY Chatroom Home Improvement Forum
Old 06-25-2010, 01:27 PM   #1
Adhesion of slate to concrete
I am about to overlay slate (12" x 12" x 1/2") onto an exterior porch and a new step and slab. The porch is 55 years old, covered by the home's roof, and is in amazingly great shape. My only concern is that the surface of the older concrete is rather smooth. (I put a broom finish on the new concrete.) I will powerwash the old concrete, but I'm wondering if I should also grind the porch surface before laying the slate. I have a man-size buffer/grinder or I could rent something a little more industrial. Perhaps the answer is simply in the thinset to use. Any pros out there with insight? Thanks, Jim
Jim in Redondo is offline   Reply With Quote
Old 06-25-2010, 03:11 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
So we're talking California, right?
Grinding would likely make the surface as smooth as it is now. I would give it a couple of acid-washes using Muriatic acid. The acid will slightly etch the surface to provide more grab for the thinset.
Use the proper thinset also. I would suggest using Mapei's Kerabond mixed with their additive Keralastic.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
Jim in Redondo (06-25-2010)
Old 06-25-2010, 03:17 PM   #3
Thanks Bud
Yep, California, so the weather isn't the harshest...
After I posted my question, it occurred to me that I had considered a muriatic acid wash. Just failed to include it. Good to get independent confirmation though. Thanks!
Tags
adhesion , concrete , grind concrete pad cement , slate
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
fixing concrete steps with slate jarby Building & Construction 3 06-04-2010 08:20 AM
concrete sealer on slate tile? the carpenter Flooring 1 03-28-2010 07:56 PM
marble tile over existing slate and concrete flooring bullrage22 Flooring 13 05-19-2008 07:58 PM
concrete step repair & slate gemelli2 Building & Construction 5 10-03-2007 06:38 PM
