Old 11-30-2009, 03:02 PM   #1
Additional Sub-floor on top of Dricore product
Good day,
I have a garage, turned rec room that has a ground-level concrete slab. I'd like to install a vapor barrier for moisture protection, raise about 3 inches to make it level with a porch area, and install some kind of flooring. After doing some reading in this forum I'd like your opinion on the following option:
- Install Dricore over the existing level slab
- Screw down 2"x4" sleepers (with rigid styrofoam insulation between the sleepers) on top of Dricore
- Screw down 1/2" plywood on top of the sleepers
- Install flooring
This would give me the moisture protection, added height (7/8" + 1-1/2" + 1/2" = 2-7/8"), and solid surface to install laminate, engineered hardwood, etc.
I am concerned with screwing the sleepers to the Dricore. Is this Ok?
Is this plan sound? Any opinions? Would I be able to install regular hardwood to the above built sub-floor?
Thanks,
- Joe
jlatulippe is offline   Reply With Quote
using Lowes edge precision flooring Andy McDonald Flooring 68 03-17-2012 02:42 PM
