Old 04-14-2010, 08:13 AM   #1
Additional girder required ....
My home is 5 years old - within the last year the floor appeared to be dropping in some areas no bigger than maybe 4-5 inches long 2 inches wide. In addition to that it has always been somewhat creaky. Our home is on a crawl space. Bottom line we had a contractor come in and look- seems that we need a girder our spacing is off.....is there an alternative???? should I get a second opinion.
richter1 is offline   Reply With Quote
Old 04-14-2010, 09:53 AM   #2
Xtreme DIY'r
Any pics of the area ? - support structure ?
Sounds like something is sinking
Old 04-14-2010, 10:23 AM   #3
Apparently the footers are good. Gentleman said that for the space their aren't enough girders...say a 22 ft room one at the start and then one at 7 ft leaving 15ft ....something like that I think. I was just wondering if there was a simpler way to correct....
Old 04-14-2010, 04:13 PM   #4
It was a dark and stormy
Yoyizit's Avatar
Your on-center joist spacing is 7'? You must have one stiff subfloor!
Girder Steel or Wood Jameson1 Building & Construction 11 03-12-2010 06:38 PM
Girder Direction JeroldLopez Building & Construction 1 08-28-2009 08:38 PM
Is a Permit required for additional light ? Handy Dave Electrical 7 09-27-2008 12:21 AM
Supporting girder with wall Geber Carpentry 3 01-29-2007 10:53 AM
additional heat required cj1clark HVAC 1 11-10-2006 09:22 PM
