Adding Radient Heat to Hardwood Floors
Ok, My house is from 1939, Forced hot air, with wood floors throughout. The only thing is that the floor for the 1st level is always cold during the fall/winter/spring and I would like to possibly put in radient heat. My basement is unfinished and unheated currently.
Would it be possible to get some of the radient floor heat components and put them between the joist against the subfloor, then insulate them in? Also, I wouldn't necessarily want the system to be running all the time, so would it be possible to hook it up to some on-demand system to just raise the floor temp then turn off? Thanks. |
radiant heat
No, the radiant heating needs to go under the wood floor. Because you have forced air heating, I'm assuming you don't have a boiler, so you'd either have to add a boiler for this -- probably not a good investment -- or use electric heating mats, which work well. You'll need to take up the floor, though. Here's a link with more info.
A better option might be to just add a baseboard electric heater in that room -- double the heating and some extra cost, but much less than tearing out the floor. http://www.oldhouseweb.com/stories/Detailed/10264.shtml |
Actually, that's an 'uninformed' answer. There is a product called Zmesh that you can retro-fit "staple up" between the joists. It is a low voltage system that is made of a bronze screen so it won't deteriorate either. It can be nailed through anywhere, glued or stapled in place without affecting the Zmesh element. Zmesh also has a 25 year warranty against defect because of this.
We've installed it in many homes. As with any radiant you'll need to then install a reflective barrier insulation then batting below it. This is all providing you have the joist height space to take all the material. You're looking for a total of R-30 or better all together. |
My neighbor keeps telling me about a product he found that attaches between the floor joists in the crawl or basement then cover it with the insulation of sorts. Sounds similar.
I am interested in the ZMesh. What type of insulation is needed for this? Do you happen to have any pictures of the installation of it in a similar manner? I'm interested in it, but need to sell the idea to the other half.
Is the floor currently insulated now? BOB |
| All times are GMT -4. The time now is 04:12 AM. |
