Old 11-01-2012, 11:38 PM   #1
Adding mass to a subfloor - am I about to do something stupid?
I have an under / over duplex with very poor sound isolation between the 2 units. The building is a 1970s wood construction, with 2x10 joists, 16" span and no insulation between the floors.
I am completely renovating the upstairs unit and want to reduce both impact and airborne noise, which requires both damping and mass. I plan to use a rubber underlay to reduce impact noise. To reduce airborne noise I am looking at adding a layer of 3/4" OSB screwed to 1/2" cement board to create a floating floor on top of the rubber mat. In combination with the underlay, I will be adding ~ 6.7 PSF dead load across the entire story floor (1000 sq ft). I plan to use carpet or vinyl tile as my finished floor so that should have minimal additional loading; however, the 2nd floor is a full 2 bedroom apartment with kitchen, bathroom, laundry room, etc.
I've read through some other threads that talk about a max. dead load of 10 PSF; however, given that I am looking at adding this underfloor across the entire 2nd story floor, could i still be creating a problem for myself? Would I be better off going with only 1" OSB or similar reduced mass?
If this doesn't produce enough noise isolation then I'll consider adding resilient channels to the downstairs ceiling + insulation but am worried that neither option will produce enough isolation on its own.
Thanks in advance!
Sara
xtrand is offline   Reply With Quote
Old 11-02-2012, 02:33 PM   #2
If it was me I'd properly install multiple layers of a sound deadening insulation between the floor joists and either reinstall, or install new subflooring. This will give you nearly a foot of sound deadening insulation to absorb any noises, plus you won't have to add all of that additional weight. I think that the insulation (can't recall the exact name) comes in 6 or 8 foot lengths, so you can pull up the subfloor a couple of sheets at a time, insulate, and reinstall the sheeting. Just make sure that you stagger the end joints in the insulation and sheeting.
FYI, if you decide that you must add more layers of subfloor then you'll want to run the new sheeting in the opposite direction that the base subfloor is running, and keep the "soundproofing" sheeting roughly 1/2-3/4 away from the wall framing. You also want to keep the sheets gapped away from each other by that same distance. Also, you can fasten the sheeting to the subfloor, just make sure that you don't hit any joists. Yes, I said don't hit any joists. This is all per national guidelines, feel free to check your local building codes regarding sound proofing between floors or a residential structure.
Also, if you were going to gap the floating OSB (you have to gap to get any real sound mitigating benefit, ie. won't transfer sound vibrations throughout the entire floor) and use the 1/2" concrete board to hold it together, or hold it in place, you're going to have some serious problems if you decide to install carpet and properly power stretch in the rooms. I'd bet money that the edges of your floating substrate will want to lift, and the expanding and contracting, as well as factoring in a floating substrate in general, will probably give you more frequent issues with your carpet wrinkling prematurely.
Anyway, just some food for thought. Good luck.
RWCustom is offline   Reply With Quote
Tags
mass, soundproofing, subfloor
What is the cost of adding brick ledge to new construction? toddtx Building & Construction 4 01-13-2011 07:04 AM
Adding Collar Ties to make a ceiling Joe1. Building & Construction 18 09-11-2010 10:56 PM
Adding more weight to truss system... what can it hold? Sonnie Building & Construction 7 02-06-2009 09:45 PM
Adding new duct/Register CEbury HVAC 1 06-25-2008 11:51 AM
