Adding Additonal Joists Use Engineered Wood? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-25-2012, 04:18 PM   #1
Adding additonal joists use engineered wood?
I have a small bathroom that I am adding a corner whirlpool tub. Weighs about 1000 lbs full.
The joist span is 82 inches and currently has 3 joists 27" o.c. (its an old house).
I plan on adding joists in between, but I only have 6.5" available height wise for new joists meaning 2x6's are the largest I can use.
Would I be better off using something like the Boise Versa-lam engineered beams since I cant use 2x10's? Are they significantly stronger then the same size 2x6?
Velvis is offline   Reply With Quote
Old 03-25-2012, 04:49 PM   #2
Civil Engineer
Rewards Points: 4,522
Step one is to determine the required strength you need, which will depend on the geometry of the load applied to each joist. In this case, you have a combination of a 1000 lb tub plus framing dead load plus live load from humans. This is an unusual case where it is probably necessary to perform mathematical computations to determine the maximum moment on your joists to determine how many extra ones, and of what type, you need.
You have indicated that you can only get 2x6 joists in due to clearance restrictions. However, your span is only about 7 feet, so you may well be able to use 2x6 joists, provided they are appropriately spaced. There is nothing wrong with I joists, however they may not be necessary. Like I say, you have to apply the loads and see what the moment on the joists turns out to be. If you are unable to perform the computations, you may need to get an engineer to do the work for you, or perhaps a contractor or a lumber yard can help. Unfortunately this is a case where you cannot use tables, due to the heavy point load combined with the distributed live and dead load.
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
Laminate vs Hard wood vs Engineered?? Gecko Flooring 1 02-22-2012 07:35 AM
Suggestions for engineered wood over OVRX insulated subfloor in basement? MasonS Flooring 2 12-14-2011 09:59 AM
Attaching Duct Enclosure to Engineered Joists Nando1 Building & Construction 2 05-03-2010 06:11 PM
Engineered or Solid Wood flooring on stairs VickyC Flooring 1 03-05-2010 07:50 PM
