Adding 2nd Layer 5/8 T&g To Stregthen Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 02-23-2012, 06:49 PM   #1
Talking
adding 2nd layer 5/8 t&g to stregthen floor
We are in kitchener ontario canada in townhouse/condo inner unit
tired of squeeky floors and bouncy china , we went about sistering a 2x6 to every floor joist (glued and screwed )
I have taken out old hardwood in living room
and old underlay-tile-vinyl-vinyl - in kitchen ,
and every sheet had a 1/8" gap or better
Then screwed down original subfloor ( 5/8 butt jointed plywood ) to every joist
(did the landing 36"x36" at front door with stairs heading up-last year--down to original subfloor and glued-screwed both to the joists and found it to be like a rock solid)
and resiliant flooring (sample from work-liked it so much we re doing kitchen the same)
so as i tried researching on putting a 2nd layer of 5/8 t&g - but most are considering this to be the underlyment layer,
My plan is to make this just thicker sub-floor -to beef up floor structure----- so after too many hdtv shows and dyi forums
- conflicting theories on attaching second layer
(sorry for long winded intro to question
- to glue or not
-to screw into joist or just in between or both
--livingroom is getting underpad and carpet
--kitchen is getting 1/4" underlayment (sureply) - this i know not to glue and screw , just staple -----then resiliant flooring
am i on track---or totally de-railed
thanks for all advises
goldberg245 is offline   Reply With Quote
Old 02-23-2012, 07:08 PM   #2
I don't have an answer for you but that seems like a ton of work for floor squeeks..
RegLearning is offline   Reply With Quote
adding a second floor to a garage h1100 Carpentry 1 03-14-2010 07:07 PM
Cost for adding a second floor Baddog77 Building & Construction 3 03-14-2010 03:08 PM
mahogany t&g porch floor, trim, stairs questions wombosi Carpentry 1 09-21-2008 09:13 PM
Help Installing Mahogany T&G porch floor wombosi Building & Construction 2 09-19-2008 01:00 AM
T&G Floor Leaks newguy4 General DIY Discussions 2 11-07-2005 10:24 AM
