Adding A 1/4" To My Floor? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-23-2010, 01:25 PM   #1
Adding a 1/4" to my floor?
I could use some input/advice. I have about 300 sq feet of a living room/hallway area that I would like to raise the floor height by 1/4". The floor is level, and in good shape. Currently, there is 1/2" plywood sheathing attached to the floor joists, & 3/4" particle board over that. I plan on laying floating laminate flooring on top of this.
Questions: What would you use, 1/4" plywood, or 1/4" OSB? How would you go about attaching it to the current subfloor, screw/nail into the joists, or just 1 1/2" screws through the particle board and into the 1/2" ply? Construction adhesive, yes/no?
littlecleo is offline   Reply With Quote
Old 03-23-2010, 03:41 PM   #2
are you accounting for the thickness of the installed finish flooring when you say you want to add 1/4"?
cellophane is offline   Reply With Quote
Old 03-23-2010, 04:20 PM   #3
Good question, and yes I am, the 1/4" is in addition to the 10mm thickness of the laminate.
Old 03-23-2010, 05:29 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Why?
XXX
Old 03-23-2010, 11:42 PM   #5
Originally Posted by Bud Cline View Post
Why?
To bring it up to the same height as my kitchen which is tile, get rid of the "step down" transition into the living room.
Adding a Second Floor Bathroom in Iowa Iowa DIYer Plumbing 1 12-26-2009 03:38 AM
Hardwood floor questions (56K) ukrainetz Flooring 1 08-02-2009 02:08 PM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 05:58 AM
Adding a 1st Floor Laundry room Profane Plumbing 3 01-25-2008 02:19 PM
adding a second floor chubdo Building & Construction 11 04-16-2005 01:20 AM
