Add Plywood To Old Sub Floor? - Flooring - DIY Chatroom Home Improvement Forum
Old 04-03-2008, 04:24 PM   #1
Add plywood to old sub floor?
Hi All,
I have an old house (about 80 years old) and we are in process of renovating.
Part of this renovation is to put down new hardwood flooring all over.
The existing sub floor are wood planks on a 45 degree angle to the existing joists. There are also gaps (as much as about 3/8") between some of these planks. Also, there are knots and other imperfections.
We spoke to some people and the feedback we received was,
1. Reuse the existing subfloor as it is, but secure it down with screws. Then just put the new hardwood over top of this. What kind of screws would typically be used for this - drywall? galvanized?
2. Screw down the existing planks, then screw down 3/8" tongue and groove plywood over top and then put down the hardwood flooring.
Does anyone have any opinions on this???
What kind of screws and spacing would be nice to know??
Thanks!
water_cutter101 is offline   Reply With Quote
Old 04-04-2008, 09:02 AM   #2
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
Option one is the traditional method. Deck screws or flooring screws. Use rosen paper between old and new floors.
Option two would be preferred if old floor has lots of issues with irregularities, gaps, etc. Still would want to screw old floor first. Wouldn't do this if you will have issues caused by height being raised.
Brik is offline   Reply With Quote
Old 04-06-2008, 11:18 PM   #3
Thanks for the advice...
We are ripping up the old hardwood flooring next weekend. We'll check out the condition of the original subfloor and then decide what to do.
Regards,
Joe.
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
Cantilevered floor insulation rickswa Building & Construction 5 01-02-2008 12:08 AM
Molde: Underside of Attic Floor stangboy68 Building & Construction 9 12-06-2007 09:53 AM
