Add Backer To Slab Floor? - Flooring - DIY Chatroom Home Improvement Forum
Old 02-23-2009, 02:30 PM   #1
Rewards Points: 83
Add backer to slab floor?
I am installing ceramic tile in a basement bath. The current floor is just the concrete slab. Do I need to put 1/4" cement board or Hardibacker between the tile and slab? Or can I just set the tile directly on the concrete? There are all sorts of scarey article out there about floor sealers, moisture and steel trowels, so I figured I should ask.
Bubbagump is offline   Reply With Quote
Old 02-23-2009, 03:14 PM   #2
K&B Remodeler/Tile Guy
angus242's Avatar
Do not use backer board over cement. You can tile directly over clean cement. That means no paint, sealers or chemicals. If the cement contains any of those, grind down to fresh cement, then tile.
If you really want some kind of underlayment, look at Ditra.
http://www.schluter.com/6_1_ditra.aspx
Angus
My Albums
angus242 is offline   Reply With Quote
Old 02-23-2009, 03:17 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 218
You do not install cement backers to concrete.....ever. If the slab is in good shape, flat and no cracks, you can thinset the tiles direct. It is better to install a membrane like Ditra first, but not necessary if it's in good shape.
Jaz
Old 02-23-2009, 03:20 PM   #4
Rewards Points: 83
Excellent... less time and expense to apply it directly. This is a 10 year old slab in good condition, so thin set directly to it it is. Many thanks!
Old 02-25-2009, 04:43 PM   #5
239 Adventurer
jbaker1516's Avatar
This answered my unasked question as well. Thanks
jbaker1516 is offline   Reply With Quote
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 03:15 PM
Bathroom 'wet floor' - floor slope options Couch Plumbing 9 03-11-2008 05:42 PM
Floor joists for 2nd Floor Addition poptop Building & Construction 4 01-11-2008 08:57 PM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 10:23 PM
Help wih floor extremer1519 Flooring 1 12-27-2005 07:33 PM
