Acrylic Group Removal - Flooring - DIY Chatroom Home Improvement Forum
Old 06-04-2010, 11:14 AM   #1
acrylic group removal
My laundry room floor is sheet vinyl with what I assume is acrylic grouting around the edges. The grouting is pulling away from the wall and discolored. How can I remove the grout without hurting the floor and what do I replace the grout with?
ariel1937 is offline   Reply With Quote
Old 06-04-2010, 12:07 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 84
Probably caulk, not grout. It should pull right up. Then replace with more caulk.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
ariel1937 (06-04-2010)
Old 06-04-2010, 02:54 PM   #3
acrylic grout removal
Thanks for the help. As a former Missourian I am sure you are correct.
Actually, it is acrylic caulk. I will try it.
Scratch in Acrylic Bathtub shadfly Kitchen & Bath Remodeling 5 07-24-2009 04:08 PM
Acrylic tub surrounds vs others? Petermgr Plumbing 1 11-08-2008 12:10 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 06:12 PM
Shouldn't use plumber's putty on acrylic tubs?? jayp Plumbing 1 06-10-2008 10:03 AM
Lead paint removal Luken8r Painting 3 05-15-2008 07:05 PM
