6x6 Tile Spacing - Flooring - DIY Chatroom Home Improvement Forum
Old 02-10-2010, 10:46 PM   #1
6x6 Tile Spacing
I'm laying 6x6 tiles in a small bathroom. Which size spacers should I use?
Any recommendations on thinset?
Red Truck is offline   Reply With Quote
Old 02-11-2010, 03:00 AM   #2
jlhaslip's Avatar
Rewards Points: 396
I would use a 1/8th inch spacer, typically, for 6 x 6 tile. possibly 3/16th. no more.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 02-12-2010, 10:51 AM   #3
remodeling pro
Is it floor or wall ? If wall application, I agree with jlhaslip, the smaller grout lines look better. If on the floor, I would have no problem with going to 1/4"; 3/16 would be ok, but I would avoid anything smaller than that on floor, except of course for small pattern such as mosiacs .
Also consider the source of the tile. Is it a known first quality product from a tile supplier to the trade, or is it from one of the numerous "tile/flooring depot/outlet" sellers. Contrary to what they tell you, much of this material is not first quality. The straightness of the edges and the tolerances for squareness of each tile is where the difference usually is. The smaller the grout lines, the more obvious these deviations become. Try dry laying a 3' x 3' square with the tiles all butted tightly; this will let you see how issues with squarness or wavy edges show up.
troubleseeker is offline   Reply With Quote
Old 02-12-2010, 12:30 PM   #4
jlhaslip's Avatar
Rewards Points: 396
Good points made in the post from troubleseeker. I assumed it was wall tile.
My bad...
and sanded grout for floors.
Old 02-13-2010, 09:39 AM   #5
Floor tile. Is there a difference in tiles for wall or floor? What about grout or thinset for wall or floor?
Thanks for the replies.
Old 02-13-2010, 12:39 PM   #6
DIY staff
Rewards Points: 7,174
Tiles are graded by hardness--mohs 3 or 4 for floors -----The tile store should be able to tell you the hardness. ----------Some wall tiles are self spacing--little bumps on the edges to provide the space.
Old 02-13-2010, 03:06 PM   #7
Rewards Points: 5,336
There is a definite difference between floor tile and wall tile. If you put wall tile on the floor, it will wear through the glazing in a short period of time. You can put floor tile on a wall without issue. There are no distinctions in grout placement, wall or floor. The issue of where to use each is based upon the tile spacing. Up to 1/8", you would use unsanded. Above 1/8", you would use sanded grout.
You want to use a modified thinset as it is better suited to flexing of the substrate. If you're putting it over Ditra, you would use unmodified thinset.
Ron
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 10:07 PM
Backerboard spacing for tile installations J187 Remodeling 5 03-18-2009 02:23 PM
Backsplash tile - spacing electric boxes bakerhouse Remodeling 8 05-15-2008 08:59 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 10:35 PM
