6x24 VS. 12x24 Tile - HELP! - Flooring - DIY Chatroom Home Improvement Forum
Old 06-21-2012, 10:03 AM   #1
Sephora's Avatar
Rewards Points: 150
Ok, give it to me straight....which size would be easiest to install?
I am having the worst time picking the tile and I finally found it and they have these two sizes. It is for a half bath.
I know these long tiles can bow....I want to know who has installed either size....tips?
I need to order today or tomorrow.
Sephora is offline   Reply With Quote
Old 06-21-2012, 11:07 AM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Yikes! Either will be a challenge. Your floor will need to be absolutely flat or lippage will be a big problem.
Even then I would recommend using some sort of leveling system.
Something like this: There are others.
http://www.tuscanleveling.com/
Old 06-21-2012, 11:28 AM   #3
Renovations contractor
Bonzai's Avatar
On floor or walls or both?
The trick is in the prep; if your walls are out of whack or the floor is bowed/cupped then you will have a really hard time. Larger tile means less grout but also less allowance regarding the substrate not being level/plumb. Also factor in the layout and which will work best with the room dimensions. Always always draw a layout first.
Home Renovations & Repairs
ADVENT HOME SOLUTIONS INC
Vancouver to Whistler & beyond
Bonzai is offline   Reply With Quote
Old 06-21-2012, 02:04 PM   #4
Sephora's Avatar
Rewards Points: 150
Floor only. Wainscoting will up half way up on floors.
This is rough mock up of room. I would do up and down layout prob 1/3 offset.
Old 06-21-2012, 08:49 PM   #5
Bonzai's Avatar
I'd go with the smaller of those sizes as buys you more design options taking in to account position of toilet and doorway ... Start off with a layout where the grout line is centered on the front of the toilet (easier to cut two half circles than one full circle in tile for the toilet drain) ... Then work towards the door and to both sides seeing if this leaves any skinny tiles ... Anything less than half a tile width is not ideal from a looks perspective. The grout line either centered on the door or a full tile centered on the door is also preferable. That's why you need to play about with it until you get something that works. You can also try checkerboard versus brick lay pattern (each row offset by half tile from previous row) to see which makes the layout work better. Spend the time figuring this out and you will be glad you did later. There are other layouts too but they can get complex if new to this.
Old 06-22-2012, 10:09 AM   #6
Smaller is easier to install. But grout is tough to clean. Short term takes a little longer to install... Lifetime... less grout makes it easier to clean. Good luck.
Thefloorman is offline   Reply With Quote
Solving discontinued tile issue timbo59 Flooring 14 10-03-2012 08:03 PM
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 01:46 PM
Removing Tile Over Hardwood: Need Help With Kitchen/Bath Creelove Flooring 3 02-01-2011 06:03 AM
Laying Subfloor for New Bathroom Question rjschwar Kitchen & Bath Remodeling 3 06-25-2010 03:06 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
