6 Mil Plastic Or 15lb Felt Under Laminate? - Flooring - DIY Chatroom Home Improvement Forum
Old 06-26-2010, 06:42 PM   #1
6 mil plastic or 15lb felt under laminate?
I am getting ready to install swiftlock laminate floors. the underlayment is already attached but I have been advised to use a moisture barrier due to the house having a moderately moist condition. Swiftlock recommends a 6 mil plastic. It is difficult to work with and a professional installer has told me that I can use roofing felt instead. Do you Pros out there agree or should I stick with the plastic. Warranty is not an issue to me but a job well done is.
thanks! Webdiva
webdiva is offline   Reply With Quote
Old 06-26-2010, 06:49 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
felt is a moisture barrier but is not a moisture vapor barrier,id follow the manufacturers recommendation
Tom Struble is offline   Reply With Quote
Old 06-26-2010, 06:54 PM   #3
Registered User
Rewards Points: 526
Is that for all climate zones, or just very cold?
http://www.fortifiber.com/aquabar_b.html
Be safe, Gary
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 08:00 AM
Cutting Plastic Laminate counter top edge (hot bit roller) Steamer2 Remodeling 2 04-01-2010 06:41 AM
15lb felt or synthetic bronco2 Roofing/Siding 3 09-26-2009 10:31 AM
how to cut, trim plastic laminate veneer alanq General DIY Discussions 2 09-19-2009 09:17 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 10:44 AM
