Old 04-18-2008, 12:52 PM   #1
6 3/4" hardwood install
I am having wide plank pine installed on 3/4" advantec sub floor, on crawl space in South Carolina (I mention local for humidity) The manufacturers instructions call for Bostik's Best adhesive INSTEAD of felt paper. (in addition to nailing) Does this sound right? Thanks...
ugabulldog is offline   Reply With Quote
Old 04-18-2008, 02:18 PM   #2
J Calvin Construction
jcalvin's Avatar
Always install per manufactures instructions. They suggest that for a reason and I would rather not find out why that is. The only thing that seems odd to me is them suggesting both. Gluing is typically for thinner flooring and nailing is for thicker flooring. But like I said, install per recommendations.
Cal
You hired WHO?
jcalvin is offline   Reply With Quote
Old 04-19-2008, 01:45 PM   #3
would using felt plus Bostiks best be even better for moisture barrier? Also, I was thinking of face nailing with cut nails, would this eliminate the need for Bostiks? and if i waited to nail till later down the road, would that be ok after gluing?
Old 04-20-2008, 01:23 AM   #4
Tileguy
JazMan's Avatar
Generally anything 5" and over is nailed and glued. Follow the manufacturer's directions. Felt paper will prevent a good adhesive bond.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Can I install 3/4" HW on top of the rolled floor membrane there now? davevarga Flooring 3 03-09-2008 11:16 PM
Install hardwood over black mastic? SuperDoug Flooring 2 10-28-2007 01:52 PM
3/4" hardwood, same direction as joists? zel Flooring 13 05-15-2007 09:50 PM
Hardwood floor install help helpless handyman Flooring 4 04-19-2007 08:53 AM
Installing Help! hardwood flooring in Hot&Humid weather dvarga Flooring 7 08-08-2005 06:45 PM
