5'X9' Entry Tile Job - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-29-2007, 03:41 PM   #16
I forgot to add...If your correct about the modified vs. unmodified thinset, which I'll look into, maybe that's why he runs a flooring store instead of a field tile setter. Just a guess.
shotdown is offline   Reply With Quote
Old 04-29-2007, 07:18 PM   #17
Hardie recommends either type of thinset under the boards, I would go with unmodifed.
R&D Tile is offline   Reply With Quote
Old 05-13-2007, 09:04 PM   #18
Fun with math!
Ok guys. Who wants to help me sandwhich this together? I am installing tile in kitchen + eating area and, 3/4" solid hardwood in other living areas. The eating area tile will abut the living room Hardwood. The entire subfloor is 3/4" plywood on 2X10 16" O.C.
The Porcelain tile is 5/16" thick. I think that gives me about 7/16" to play with. If some think the existing 3/4" plywood subfloor is inadequate then, How would you best remedy this dilemma? All serious inquires will be considered? Also, What would you consider too risky?
Old 05-13-2007, 10:57 PM   #19
Rewards Points: 1,442
FWIW:
In my application I removed the underlayment AND the sub-floor.
Installed 2x cleats on the floor joists, installing two layers of 3/4 ply on top off the cleats, between the joists, installed a layer of 1/2 ply on top those 2 layers and the joists, then installed 3/8 backer board over that. All layers glued and screwed.
Porcelain tile is now dead even with the adjoining 3/4 hardwood flooring.
If you don't have enough material under the tile, the grout will continously break out due to the floor flexing. Or worse yet the tile will crack along joist lines.
ktkelly is offline   Reply With Quote
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
HELP! Tile flooring question Marsy Flooring 1 02-16-2007 10:22 PM
Tile roof questions/repairs help please xoroniox Roofing/Siding 3 12-17-2006 03:02 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 03:14 PM
