5/8" OSB As A Subfloor. - Flooring - DIY Chatroom Home Improvement Forum
Old 09-08-2011, 12:40 AM   #1
5/8" OSB as a subfloor.
I'm planning on installing 3/4" maple hardwood floors on the upper level of my home. The subfloor I discovered when I pulled the carpet is 5/8" OSB. I plan on laying the planks perpendicular to the joists (16" on center). Can I do this? Is the subfloor sufficient? What would I need to add if it's not good enough. I'm hesitant to add more subfloor as it will make the top step of the stairs much different then the the other steps.
Looking for advice,
Thanks!
Taplight is offline   Reply With Quote
Old 09-08-2011, 10:15 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 288
You're fine, especially since you're installing hardwood. Your instructions should also mention subfloor requirements.
Jaz
Old 09-08-2011, 11:38 PM   #3
Rewards Points: 200
From NWFA
"Acceptable Panel Subfloors: Truss/joist spacing will determine the minimum acceptable
thickness of the panel subflooring.
1. On truss/joist spacing of 16 (406mm) o/c or less, the industry standard for single-panel
subflooring is nominal 5/8 (19/32, 15.1mm) CD Exposure 1 Plywood subfloor panels
(CD EXPOSURE 1) or 23/32 OSB Exposure 1 subfloor panels, 4 X 8' sheets. "
Floor Doc is offline   Reply With Quote
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 07:29 AM
Replacing Subfloor whatispunk Flooring 1 09-01-2009 10:50 PM
Subfloor Help, Please! OmahaGirl Flooring 1 01-26-2009 09:06 AM
Hardwood floors installed over 1/2" and 5/8" subfloor interplexr Flooring 1 01-25-2009 02:00 PM
Subfloor / underlayment question... scheenstra Flooring 7 02-21-2008 08:39 AM
