5/16" Brazillian Chestnut DIY Install - Flooring - DIY Chatroom Home Improvement Forum
Old 08-01-2011, 12:24 PM   #1
Hello - New homeowner here. Just bought a foreclosure that I am completely gutting and fixing up. I'm at the flooring stage and just bought 5/16" Brazillian Chestnut to install from lumber liquidators. I'm a little nervous about doing this myself and the more I read the more concerned I become. I was wondering if anybody has installed this before and can give me advice on the right nail gun to use? Or, should I be gluing this instead? I'm doing about 900 sq feet of my house and any advice at all would be helpful. I have a plywood subfloor. Thanks!
jaredm_k is offline   Reply With Quote
Old 08-01-2011, 12:33 PM   #2
Rewards Points: 150
Nothing special installation wise about that type of wood. Here is the nailer you need.
http://www.homedepot.com/Flooring-Fl...atalogId=10053
You might be able to rent one. Also, home depot has a how to book on flooring installation that is actually really good. I'd get it, for one thing it teaches you how to get everything lined up.
I would nail instead of glue. It's more forgiving since you can go slow and redo if necessary. Glue has a time component as it dries.
Broughton is offline   Reply With Quote
Old 08-02-2011, 07:12 AM   #3
Thanks for the info! That gun says it is for 1/2" to 3/4" hardwood. Will it be OK with my 5/16" brazillian chestnut since it is a harder wood? Thanks again and I will definitely be checking out the book at Home Depot!
Old 08-02-2011, 07:21 AM   #4
DIY staff
Rewards Points: 7,174
Have you read the instructions yet? What does the manufacturer recommend?
Old 08-02-2011, 09:08 AM   #5
Rewards Points: 150
Tell me the brand and if it is engineered or hardwood and I'll tell you the gun they recommend.
Old 08-02-2011, 09:14 AM   #6
It is Bellawood solid hardwood. Thanks again!
Old 08-02-2011, 11:18 AM   #7
Rewards Points: 150
Ah, well bellawood has no specific recommendations.
Borrowing from armstrong they recommend Solid 5/16" - Stanley-Bostitch S32SXBHF, Stanley-Bostitch SX150, Senco SLS20HF, or other machine designed or adapted specifically to 5/16″ solid flooring.
There is also a thread that floorguy responded to here that you might find helpful.
http://www.doityourself.com/forum/so...tallation.html
Old 08-02-2011, 11:19 AM   #8
Rewards Points: 150
Need to install a water pressure regulator Doug Crf Plumbing 2 06-20-2009 01:23 PM
cutting shingles to install gutters Chicago Bill General DIY Discussions 2 02-27-2009 05:42 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
When to install tile flooring? MT Stringer Remodeling 4 10-28-2008 08:49 PM
How to install resilient channel on ceiling Bcoleman6 Building & Construction 1 08-22-2008 02:29 PM
