3/8 Brazillian Cherry - Flooring - DIY Chatroom Home Improvement Forum
Old 01-09-2010, 09:43 AM   #1
Rewards Points: 49
3/8 brazillian cherry
I am in the process of putting down 3/8 brazillian cherry flooring in my house. In the past I have always run it opposite of the floor joist. I have floor joist 3/4 OSB board. My question is can you run it with the joist? I know you would only be nailing into the OSB and I am wondering if this is a bad idea? Would like to have your opinion guys. Thanks, worker 903.
worker903 is offline   Reply With Quote
Old 01-09-2010, 05:30 PM   #2
msv
Hardwood pro
msv's Avatar
installation is supposed to be perpendicular to the floor joists far added support when you have heavy pieces of furniture(at least that's one of the reasons). also, running it accross the joists, allows you to nail each and every board to the joists(through the subfloor) for added durability of your flooring. What method are you gonna use for installation? (nail/staple or glue)?
50% down, 50% after all your complaints....
Hardwood Floor Refinishing Roswell
msv is offline   Reply With Quote
Installing 3/8" solid Brazilian Cherry silverbullet Flooring 6 01-02-2009 05:58 AM
transition from brick floor to brazilian cherry floor rockey Flooring 4 12-08-2008 12:55 PM
possibly pulling up recently laid Brazilian Cherry wood floor rockey Flooring 6 11-05-2008 01:03 PM
Cherry Wood steveotti Carpentry 6 03-11-2008 07:21 PM
Staining solid cherry wood Woodcutter Painting 7 12-26-2007 08:03 PM
