3/4inch Hardwood Over Parquet - Flooring - DIY Chatroom Home Improvement Forum
Old 04-29-2011, 10:57 AM   #1
3/4inch hardwood over parquet
Hello all,
Some great advice here, thanks! I have a question regarding installing 3/4inch nail down hardwood flooring over an exisiting parquet floor - essentially: Should I do it?
The 'plan' would be to lay an additional layer of plywood over the parquet, glueing/screwing it right through into the joists, then 2" nailing the wood.
1 - the floor squeaks now (carpet over parquet), should I screw through the 'subfloor' prior to the extra layer of plywood?
2 - is a 3/8 inch plywood adequate, given that it's an extra layer only?
3 - is the risk of the parquet splitting / loosening due to the screwing and nailing too great, so as to cause squeaking down the road?
I've done wood before, but never over parquet like this...Thanks!
Bryan-
snoots is offline   Reply With Quote
Old 04-29-2011, 11:15 AM   #2
DIY staff
Rewards Points: 7,174
I'd peal off the old parquet---then rescrew the squeeky subfloor---add more ply to that if needed.
The old parquet is very likely to splinter and cause you problems.
Old 04-29-2011, 10:11 PM   #3
id remove the old floor, fix the squeaks and put the hardwood over that.
the other way you would be raising the floor level 1-1/8 higher then the existing floor thats there now.
this way the floor might be closer to the other floors
The Following User Says Thank You to DannyT For This Useful Post:
oh'mike (05-01-2011)
Installing new hardwood ontop of existing hardwood benshouse Flooring 4 01-10-2014 12:45 PM
Lay New Hardwood On Hold Hardwood TJfive0 Flooring 3 04-30-2011 05:50 PM
Refinish/match old parquet or new hardwood? rational Flooring 1 04-29-2011 10:25 PM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 11:56 AM
Want to try to refinish hardwood floors and parquet floors proofer Flooring 11 04-20-2008 05:59 PM
