3/4" Solid Hardwood - Glue Down On Concrete - Flooring - DIY Chatroom Home Improvement Forum
Old 08-01-2010, 01:36 AM   #1
3/4" Solid Hardwood - Glue down on concrete
I live in Dallas and am looking to install 3/4", 5" wide African Okan solid hardwood on my concrete floor. Is it a good idea to glue it down? I am planning on using Mapei ultrabond 995 which provides moisture barrier too. How good are these moisture barriers ? Will they prevent the moisture from getting to the wood plank?
I am confused because I am getting conflicting advise on whether or not I can glue down this hardwood.
Installing a plywood subfloor[ 3/4" OSB] and then nailing the hardwood would raise the floor level and I do have several existing tiled surface and am worried about 1.5-2 inch difference in height.
Appreciate your time and help in this matter.
Thanks!
kk171 is offline   Reply With Quote
Old 08-01-2010, 05:18 PM   #2
Rewards Points: 264
You will for sure need to do a moisture test. And check the mfg recommendations. For years the rule was no hardwood glued to a slab, but I think some of those rules are changing with the development of the new adhesives. I am going to use an engineered product for gluing to the slab, that is what all the floors guys around here suggest.
7echo is offline   Reply With Quote
Old 08-01-2010, 07:21 PM   #3
Thank you for your response.
Tags
concrete , glue , hardwood
Can I open the window at night if have solid hardwood floor installed qhwang Flooring 6 06-30-2010 09:36 AM
3/4" hardwood over 3/4" T&G subfloor benjamincall Flooring 16 03-18-2010 10:46 PM
Concrete.. Better than Hardwood ? Alessandro Flooring 2 09-25-2009 08:07 PM
Does 5" Hardwood Solid need to be glued down as well as nailed down. reibuild Flooring 2 08-03-2007 10:37 PM
Hardwood in kitchen over concrete slab Markvonjinn Flooring 12 05-09-2006 09:37 AM
