3/4" Brazilian Walnut Solid Hardwood. - Flooring - DIY Chatroom Home Improvement Forum
Old 05-22-2011, 03:20 PM   #1
3/4" Brazilian Walnut solid Hardwood.
Well, since looking on your site, I am definately changing my plans...but I really need to know the BEST way to have this flooring installed, on concrete, in Florida. I have yet to find a laminate or engineered flooring that I feel will be durable enough for the pricepoint, so, if I am going to do wood at all, I want a solid hardwood. Is it advisable to put down some kind of waterproofing product? Can I glue down the subfloor with the Bostic's glue that includes the moisture barrier? Someone also suggested putting roofing felt down between the plastic and subflooring layers, has anyone ever heard of this?
scrubce is offline   Reply With Quote
Old 05-22-2011, 04:14 PM   #2
you cant put solid 3/4 hardwood flooring over concrete. engineered or laminate. have you seen the wood look tile?
i guess if you want to put a moisture barrier and sleepers and plywood you could but that will raise the floor 2-1/4 inches but that would be up to you.
but it cant be installed right over the concrete. engineered can be glued right to the concrete but i would rather float it.
i know what you mean about finding a laminate and engineered that you like, we went with unfinished 3/4 tigerwood and i finished it. we just didnt care for the glossy prefinished or the microbevels.
Old 05-23-2011, 12:25 AM   #3
If you are set on putting 3/4" solid hardwood over the concrete the only method is to attach plywood to the entire surface of the concrete. Then use some roofing tar paper on top of the plywood and nail it down to the plywood. You do not want to glue 3/4".
RhodesHardwood is offline   Reply With Quote
3/4" Solid Hardwood - Glue down on concrete kk171 Flooring 2 08-01-2010 07:21 PM
Can I open the window at night if have solid hardwood floor installed qhwang Flooring 6 06-30-2010 09:36 AM
Brazilian Walnut Plank Stability JDeFuria Flooring 3 03-13-2009 05:38 PM
Installing 3/8" solid Brazilian Cherry silverbullet Flooring 6 01-02-2009 05:58 AM
Hardwood - engineered vs solid? cbeingessner Flooring 12 05-19-2008 10:37 AM
