3/4 Hardwood Underlayment - Flooring - DIY Chatroom Home Improvement Forum
Old 08-09-2012, 08:00 AM   #1
Hi all,
Just a quick question RE: underlayment. We are planning to put hardwood floors in our living/family room, and kitchen. I pulled up the carpeting in the living room, and saw that it was particle board over plywood. I knew I had to rip up the particle board because it won't work for hardwood, so I've spent the past day doing it.
When I made it to the kitchen, however, I discovered that it already had plywood underlayment. This is where my dilemma is. The plywood down in the kitchen is 17/32, and the stuff I had delivered to my house (I dont have a truck) is 15/32. Is this 1/16" enough of a difference to worry about either returning the plywood I have, or ripping up the kitchen underlayment? Could I make the transition work with a roofing shingle? The rooms meet in a doorway, so it's not a huge transition in terms of length.
Thanks for the help in advance.
the_hoff is offline   Reply With Quote
Old 08-09-2012, 12:30 PM   #2
Builder and Remodeler
JohnCarpenter's Avatar
I would send it back and get the same thing. Squeeks are going to be from the floor riding up and down on nails. If there are dips that can cause an air pocket between the hardwood and subfloor, it will squeek. Doing remodels, I see leveling compound cracked and falling apart on wood subfloors all the time.
JohnCarpenter is offline   Reply With Quote
Solid hardwood floor underlayment insulayment silence quiet shinyhalo Flooring 14 11-27-2012 09:02 PM
Installing Bamboo Hardwood, wondering about underlayment. coderguy Flooring 14 02-22-2011 11:55 PM
Best underlayment for Engineered hardwood on concrete jcieutat Flooring 0 11-28-2009 05:14 PM
Underlayment for Hardwood datavortex Flooring 3 11-09-2008 05:49 PM
Hardwood floor installation on 2nd floor - underlayment necessary? digexpressions Flooring 2 11-30-2007 11:15 AM
