3/4 Hardwood Install In 23 X24 Room - Flooring - DIY Chatroom Home Improvement Forum
Old 04-20-2009, 12:06 AM   #1
3/4 hardwood install in 23 x24 room
We have just completed an expansion of our great room from 14 x 16 to 23 x 24 and are going to install 4" wide by 3/4 thick plank flooring. I know from the previous thread and other literature that you should be installing the floor perpendicular to the joists. The problem is the joists of the expansion run opposite to the joists of the original room. The subfloor is 3/4 t&g. If we add 1/2 on top of this for rigidity it will put us out of whack with our current adjacent tiled rooms. Is blocking between the joists a remedy (if so, what is the minimum size and spacing that we can get away with). If this is not really an issue let me know that also.
Much appreciated. Bill T
Will Jim is offline   Reply With Quote
Old 04-20-2009, 06:13 AM   #2
Wood Floor Guy
New addition
You're in luck! It's pretty common today to install 3/4" flooring directly over 3/4" plywood. In fact, NOFMA (Nat. Oak Flooring Manufac. Assoc) approves it. See www.norfma.org . The only things you have to be careful of are:
1. Joist spacing needs to be on 16" centers.
2. Tighten up your nailing pattern on your flooring. 6" spacing max.
Hope this helps!
Wood Floor Guy
Last edited by AtlanticWBConst.; 08-20-2009 at 02:53 PM. Reason: RULES VIOLATION: Advertising Link Removed From Signature
Wood Floor Guy is offline   Reply With Quote
install trek on flat roof of another room to creat deck? ckurita Building & Construction 11 05-23-2009 09:29 AM
Vents from boiler room RammsteinNicCage HVAC 3 03-11-2009 07:28 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Upstairs Laundry Room Install Matt Burks Remodeling 3 08-21-2007 11:12 PM
Pattern of hardwood to existing hardwood floors garnet4ever Flooring 4 07-31-2007 03:34 PM
