Old 07-08-2009, 07:22 AM   #1
2 Questions (luan vs Multiply) & ceramic transition piece
1st is any suggestions on 1/4" luan vs something called (multyply). just wandering about price and if necessary. my guess is the vinyl is cheaper and they would ike me to put down a better underlayment.
2nd is what to use as a good transition from ceramic to 3/4" hardwwod floor. ( somthing attached to ceramic or just a wood T transition after both are istalled
Jb#24 is offline   Reply With Quote
Old 07-08-2009, 10:42 AM   #2
Flooring Materials
fastfloors's Avatar
This article might help you answer your second question. Hope it helps!
http://www.homeconstructionimproveme...wood-and-tile/
fastfloors is offline   Reply With Quote
Old 07-08-2009, 11:37 AM   #3
Tileguy
Bud Cline's Avatar
WOW! That statement is making no sense to me.
If you are talking about a ceramic tile underlayment then forget about the luan. Luan is specifically poo-poohed by the entire tile industry and it says so everywhere you look. If you are installing vinyl then I suppose it is acceptable.
Multiply is a brand name, I have no idea what it is used for. What does their instructions say?
Shouldn't be using plywood (only) for a ceramic tile tilebacker anyway.
Your choice.
The abovementioned website has some good information if it wasn't for the phony question and answer segment. That's been faked. I think the guy is selling books more than anything else.
Quarter round around door casing and transition piece chippydale Flooring 5 07-04-2009 09:44 AM
Laminate Flooring Questions middie Flooring 3 05-28-2009 05:03 PM
Transition from hardwood to ceramic tile. tmbrink Flooring 1 03-09-2009 01:04 AM
Transition Piece Required?? John S Flooring 5 09-25-2008 06:39 PM
Marble to Ceramic tile transition stormsurfin Flooring 3 06-18-2008 11:46 PM
