Old 10-10-2011, 09:13 PM   #1
2 methods of installing hardwood-which is best
We are going to have new hardwood floors installed and have gotten 2 very similiar bids however their methods of installing the floor are different. #1- Bring floor in 1 week prior or aclimate to the area, install & stain & finish immediately. #2 Install floor immediately and then let it sit for 3 weeks to aclimate & then stain & finish. Which way is the best way to have the floors installed? Thanks
John/Suz is offline   Reply With Quote
Old 10-10-2011, 09:33 PM   #2
First you have to acclimate the house before you even bring the wood there . then open the boxes and let it acclimate to the site conditions .
Time has nothing to do with acclimation. MC , RH , and temp readings must be taken .
Floor Doc is offline   Reply With Quote
The Following 3 Users Say Thank You to Floor Doc For This Useful Post:
Bud Cline (10-12-2011), John/Suz (10-11-2011), rusty baker (10-12-2011)
Old 10-12-2011, 12:25 AM   #3
Moisture reading have to be taken on the wood being delivered that day, as well as your sub floor that day. If they're off by more than 2 points, wood cannot be installed. It's best to acclimate wood a week in a heated home, between 65 and 75 degrees with humidity levels between 50 and 65%. You can kill the tree but you can't kill the wood. It will always continue to expand and contract depending on the seasons and your heat/humidity levels. That said, acclimating first then sanding and finishing the wood is what we recommend, assuming it's 3/4" domestic wood. If it's an exotic species, it may have to acclimate a bit longer. Density is greater on exotics.
Distributor Rep is offline   Reply With Quote
The Following User Says Thank You to Distributor Rep For This Useful Post:
Old 10-12-2011, 07:32 AM   #4
Pro Flooring Installer
rusty baker's Avatar
Floor Doc is exactly right. Many salemen and installers don't understand. Time is not acclimation.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 10-12-2011, 12:49 PM   #5
Mark Potter's Avatar
So the hole linoleum and floating floor aspect of leaving it in same room as its being installed in for 24hrs goes right out the window?....
Mark Potter is offline   Reply With Quote
Old 10-12-2011, 01:25 PM   #6
Linoleum just needs to be warm enough to handle. As far as floating floors, it depends on what you are floating.
Old 10-12-2011, 01:45 PM   #7
By "floating floor" I'm assuming you mean the interlocking laminate... which has to acclimate for 48-72 hours as per manufacturers recommendations....
Bad Example is offline   Reply With Quote
Old 10-12-2011, 01:48 PM   #8
Yes that's what I meant to say interlocking laminate.
Old 10-12-2011, 01:51 PM   #9
That is a temp acclimation. Hardwood needs a moisture acclimation. 2 different animals.
Old 10-12-2011, 02:00 PM   #10
Right I was commenting on mark potters post... not the original question
Old 10-13-2011, 12:51 AM   #11
Thanks everyone for your help. As suggested we will take the moisture reading of both the flooring and subfloor. It is red oak we are installing.
Installing new hardwood ontop of existing hardwood benshouse Flooring 1 11-13-2009 11:25 AM
Installing engineered hardwood flooring over concrete deborahs Flooring 3 07-30-2009 10:35 PM
Method for installing 3/8" engineered hardwood poolecw Flooring 10 10-31-2008 04:10 PM
Installing Hardwood Flooring selical Flooring 4 10-24-2008 11:45 AM
Installing Hardwood Floor Frank Pantusco Flooring 1 10-26-2007 11:17 PM
