1st Coat Of Polyurethane Done, Too Late To Fix Small Patch - Flooring - DIY Chatroom Home Improvement Forum
Old 04-25-2011, 06:32 PM   #1
1st coat of polyurethane done, too late to fix small patch
I'm in the process of redoing my parquet. I noticed there's a small yellow patch bordering the wall. I must have missed it when sanding. I've put down one coat of water based varathane. Is it too late to sand off the first coat and the wood of that one area and reapply the varathane?
I'd like to have this redone but it won't bother me if it's not feasible.
aldgagnon is offline   Reply With Quote
Old 04-27-2011, 09:10 AM   #2
Too Short? Cut it Again!
Just be careful and plan on building up the area you sand off to match your first coat on the floor overall as best you can. Then proceed with your subsequent coats.
Obviously now is the time to fix it if it bothers you. Once you get subesequent coats on it will just get harder to deal with.
Old 04-27-2011, 09:14 AM   #3
I ended up scrapping off the first coat & the underlying yellow areas with a wood scraper, hand sanded the area with 100 grit paper, reapplied the poly with a brush to the effected area. Took a look at it this morning and it seems fine.
Bad driveway patch and seal work fastfan Landscaping & Lawn Care 1 09-09-2009 08:14 PM
Can you put brown coat on if it's going to rain? Not Sure Building & Construction 3 03-23-2009 06:57 AM
Repairing a small hole in drywall jweiner Drywall & Plaster 9 01-28-2009 08:53 PM
Particles showing through the polyurethane over my newly-sanded hardwood floors proofer Flooring 3 12-10-2008 08:42 AM
How to level small patch of cured concrete? RDS General DIY Discussions 11 06-05-2008 12:41 PM
