1984 House Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 08-04-2011, 09:46 PM   #1
1984 house flooring
I ripped one layer of flooring and found another layer underneath. Been reading online about vinyl flooring having asbestos in it. Was wondering how to tell if the floor has asbestos in it or not. Floor looks like the previous owner took part of the layer up. Was wondering if the previous owner tearing the layer up and the decided to put a floor over it. Doe this mean that the layer I am looking at may have asbestos in it or not? Confused because the govt banned it prior to 1978 and house was built in 1984. Just trying to make sure.
drodjered06 is offline   Reply With Quote
Old 08-04-2011, 09:51 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
It may have been banned in '78 but inventories didn't run out until well into the 80's. The only way to tell is to have it tested by a testing lab. That's easy enough to do if you are so-inclined.
If it does contain asbestos do you want to remove it or are you going to have a heart attack because of it. We don't do heart attacks here.
XXX
Old 08-05-2011, 05:59 AM   #3
Yes this is what I was confused about when most pages say in the 70's building materials started to not use asbestos in the products. I asked a couple of other contractors that I know and they said that the flooring should not have asbestos, but I think I am going to get tested just have a piece of mind. I have two little ones and we are remodeling our kitchen, which involves ripping up the flooring down to the sub-floor and cabinets. I have done the first layer, since I did not know there was another layer until I was well into it. In any case the layer that is exposed has some vinyl missing and it has a white layer exposed in some areas. I also see the underlayment under that the vinyl was attached too. How long does the test take to get done? Would it be a good idea to rip it all out of there, since it is already exposed and some of the first layer has been ripped up?
Old 08-05-2011, 08:12 AM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
It's never a good idea to heap layers of floor coverings on top of layers of floor coverings. If you don't grind or sand or chew on the vinyl, or put it on your salad, you can safely handle it to get rid of it.
XXX
Old 08-05-2011, 08:56 AM   #5
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 182
I personally would have it tested,but that's up to you. I like to know what I'm working with. I've been told that some leftover asbestos containing floor covering was sold into the 90's.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 08-05-2011, 03:36 PM   #6
Mold!! Let's kill it!
Rewards Points: 2,012
Asbestos tests are cheap and quick.......... and create piece of mind. My bet is that it's not ACM (asbestos containing material). The U.S. EPA attempted to ban asbestos in the late 70's and early 80's. A lot of manufacturers complied voluntarily, but the courts ruled that the EPA had no authority to ban anything, only to regulate any process that may create an environmental hazard. No official legal ban ever existed for asbestos in building products and still doesn't You can still buy asbestos containing products on the U.S. open market. If the Chinese sell toys with lead paint and drywall that corrodes your wiring, imagine what else may be coming in. OSHA probably contributed more to the reduction of asbestos by it's guidelines to protect workers on production lines where at least U.S. products originated.
Old 08-05-2011, 04:00 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
From below .gov webpage:
"On July 12, 1989, EPA issued a final rule banning most asbestos-containing products. In 1991, this regulation was overturned by the Fifth Circuit Court of Appeals in New Orleans. As a result of the Court's decision, the following specific asbestos-containing products remain banned: flooring felt, rollboard, and corrugated, commercial, or specialty paper."
http://www.epa.gov/asbestos/pubs/ban.html
XXX
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Big water leak under house Puzzles Plumbing 4 04-27-2011 02:50 PM
My new project, 31 year old house... Axhammer General DIY Discussions 3 04-08-2009 08:46 AM
Moving a House 70 miles- Practical? GOTHICrevivalRULES Building & Construction 19 11-27-2008 08:58 PM
Will Laminate Flooring Hold Up With Dogs In The House? FEDERAL GOON Flooring 3 06-18-2008 01:39 PM
