1900's Hardwood Remove Before Adding Underlayment? - Flooring - DIY Chatroom Home Improvement Forum
Old 04-13-2015, 12:22 PM   #1
Rewards Points: 20
1900's hardwood remove before adding underlayment?
Hi guys, some of you may know me from the contractor board. I'm remodelling a 1900's home, not without probably all problems that a 1900's home could have.
The house has old hardwood floors, that are mostly damaged beyond repair, so for the most part I'm going to put laminate overtop.
My question is, one particular bedroom has a lot of squeaking. Should I remove the hardwood, rescrew the old subfloor, then build up my underlayment? Or will putting my 12 mm laminate with underlayment attached eliminate a lot of squeaks? I'm trying to keep the cost down... so of course I know removing the hardwood and screwing the subfloor would be most beneficial. But would it be essential?
Thank You for your Help!
antropovsky is offline   Reply With Quote
Old 04-13-2015, 12:45 PM   #2
Rewards Points: 716
Laminate is the devils spawn. It's loud and hollow, goes to gather poorly and looks like crap.
Why not some refinished hardwood?
Anti-wingnut is offline   Reply With Quote
Old 04-13-2015, 01:00 PM   #3
Rewards Points: 2,978
The padding and laminite is not going to do a thing to quiet down the squecks.
Old 04-13-2015, 02:39 PM   #4
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 2,738
Why not engineered? It looks and lasts a lot better than laminate and isn't a lot more expensive.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 04-13-2015, 05:57 PM   #5
DIY staff
Rewards Points: 4,762
As to your squeak question---you will be able to stop the squeaks with lots of screws through the hardwood into the old skip sheeting---but in my experience--it will be cheaper and faster to cut out the old hardwood---
Often the squeaks are from the skip sheeting---so you will be spending hours tracking down the worst of them---often the framing on the antique houses is oak or petrified fir---which may snap your screws.
Old 04-14-2015, 02:54 AM   #6
Rewards Points: 2
Laying OSB overtop usually fixes the problem, in my experience. The weight on the old floor is distributed, plus youre screwing it down.
Also, you have a flat surface to work on. Otherwise leveling concrete is often necessary.
JourneymanBrian is offline   Reply With Quote
Old 04-15-2015, 09:23 AM   #7
Rewards Points: 20
Thanks for your response, this was the direction I was leaning towards.
Best option for subfloor when adding tile over hardwood KansasCity Flooring 4 02-22-2014 08:39 AM
Best way to remove old vinyl's backing from particle board underlayment richapple Flooring 9 11-11-2013 05:07 PM
PL premium on hardwood flooring - how to remove? annette.arial@bell.ca Flooring 5 10-18-2013 05:32 PM
Remove hardwood for tile headcrash0101 Flooring 5 06-23-2008 02:21 PM
Hardwood has a subfloor on top that I would like to remove capslock Flooring 3 04-01-2008 10:27 AM
