19"x19" Tile, What Thickness Edging To Use - Flooring - DIY Chatroom Home Improvement Forum
Old 08-17-2012, 09:30 PM   #1
19"x19" tile, what thickness edging to use
So I will be installing these tiles soon, they are 3/8" thick and i will be using a 1/2" trowel. just wondering what thickness tile edge to use.
They are wall tiles for a tub surround.
hammerinhand is offline   Reply With Quote
Old 08-17-2012, 09:46 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 290
Hi,
Well, OK, they are floor tiles being installed on walls. I doubt they are really 3/8", probably 1cm, which is close. I supposed by edging you mean the metal "L" edgings like this; http://www.schluter.com/products.aspx , either the Schiene or the Jolly. Is there no bullnose trim tiles to match the tiles available?
If you have to use the metal, go with 1/2". Hope those walls are very flat in every direction.
Jaz
Old 08-17-2012, 10:29 PM   #3
Pro
JetSwet's Avatar
Rewards Points: 502
You might want to tap some small roofing nails to hold up the tiles or will crush the spacers and you will never get them out.
JetSwet is offline   Reply With Quote
Old 08-17-2012, 10:35 PM   #4
Rewards Points: 150
Try rondec or bulnose. 1/2 trowel is too small.
OhioHomeDoctor is offline   Reply With Quote
Tags
ceramic , edging , install , surround , tile
new ceramic tile over 12x12 ceramic danthebuilder Tiling, ceramics, marble 4 08-09-2011 01:03 PM
tiling - difference in thickness. glass tile vs porcelain jbitt Kitchen & Bath Remodeling 2 06-13-2010 03:22 PM
Vertical tile on wall poolecw Flooring 2 06-01-2010 11:05 AM
Where do I make my tile cuts for the wall? petsparkle Kitchen & Bath Remodeling 6 04-25-2009 11:00 AM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
