-   -   19"x19" tile, what thickness edging to use (http://www.diychatroom.com/f5/19-x19-tile-what-thickness-edging-use-154058/)
hammerinhand 08-17-2012 08:30 PM
So I will be installing these tiles soon, they are 3/8" thick and i will be using a 1/2" trowel. just wondering what thickness tile edge to use.
They are wall tiles for a tub surround.
JazMan 08-17-2012 08:46 PM
Hi,
Well, OK, they are floor tiles being installed on walls. I doubt they are really 3/8", probably 1cm, which is close. I supposed by edging you mean the metal "L" edgings like this; http://www.schluter.com/products.aspx , either the Schiene or the Jolly. Is there no bullnose trim tiles to match the tiles available?
If you have to use the metal, go with 1/2". Hope those walls are very flat in every direction. :whistling2:
Jaz
JetSwet 08-17-2012 09:29 PM
You might want to tap some small roofing nails to hold up the tiles or will crush the spacers and you will never get them out.
OhioHomeDoctor 08-17-2012 09:35 PM
Try rondec or bulnose. 1/2 trowel is too small.
