18x18 Travertine Stone Tile Install... - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-30-2007, 09:11 PM   #16
Alot of misinformation or not complete info to do the job correctly, at least when it comes to tiling.
IMHO, I would never set 1/2" stone in sand, will always move, should be mortared or thinsetted to a concrete base, Concrete & Brick pavers are 2"+ thick and lock in place, they can be installed over a sand base.
If they rock, there's space under them and not 100% flat in the sand, lift the ones that rock and reset them, hope it helps.
R&D Tile is offline   Reply With Quote
Old 10-19-2007, 08:30 PM   #17
18 by 18 tile
Hey- does anyone know the best tool to cut 18 by 18 inch tile...i went to home depot but their rental equip. only cuts up to 12by 12 tile...thanks
bobloj is offline   Reply With Quote
Old 10-19-2007, 11:46 PM   #18
Tileguy
JazMan's Avatar
Rewards Points: 224
Home Depot....try a real tile shop. You might have to take them to a stone fabricator since the saw you'll need is kinda pricey to find at many rental stores.
Jaz
Old 10-19-2007, 11:54 PM   #19
Home Depot sells a cheapy tile tablesaw unit for around $100 and I did all my cuts with it. You can cut any size tile with since it is like a table saw. For a DIY it is okay, but not super accurate or that convenient. It got the job done.
Hages is offline   Reply With Quote
Can I install 12x12 porcelain tile on a shower wall or ceiling? dezigner80 Remodeling 6 09-15-2009 01:05 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
leveling floor 2" for tile install! matty Flooring 2 08-04-2007 02:15 PM
Help! What is Proper Way to Install Manufactured Stone? EricW Building & Construction 3 01-07-2007 04:56 PM
Stone tile sealing help kumar35885 Flooring 1 12-13-2005 08:39 AM
