Old 03-11-2008, 05:03 AM   #1
1.75" room / floor transition
I have a room to room transition that is causing me issues. I have a tile
hallway to a tile laundry room that has a 1.75" transition between the
two rooms. It's in a path that doesn't get used a lot so it's easy to
forget that it's there and I've kicked it a few times or put my foot down
on it mid-transition while carying something and it's caused me some
issues. The fact that it's tiled is an issues because there is a sharp / crisp
edge on the tile transition.
The hallway to den transition has the same 1.75" difference but it's
carpeted and it's the main path and it's easier to train your self that
you have to step differently there...
Anyway... I'd like to put in a ramp of some sort that is 1' deep, 3' wide
and has a 1.75" rise over that 1' run.
Are there any pre-maid ramp materials that I can use for something
like this that I can find at home depot or lowes? Is there a 'standard'
for doing something like this?
( FWIW: the slab height difference is between the garage and the
rest of the house. The garage enters the hallway and has 4 doors....
2 doors ( garage and office ) are at one level and 2 doors ( laundry room
and den ) are at the 2nd, 1.75" level. )
jack
MrLinux is offline   Reply With Quote
Old 03-11-2008, 03:19 PM   #2
Tileguy
Bud Cline's Avatar
The first thing that comes to mind is carpet shims to make your transition gradual. You would have to stake these to get your 1.75. This type of shim is also available in a rubber product.
http://www.carpetshims.com/installing_super_shims.html
You could also do this using ceramic tile.
A cabinet shop could make a reducer from either wood or solid surfacing material. There are several ways to do this.
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Heat pump in non insulated nor heated room robdville HVAC 3 01-21-2008 03:51 PM
Hardwood flooring - 3 walls and a sunken living room basledder Flooring 1 12-09-2007 06:34 PM
Room to Room Vent cjpilot HVAC 5 12-02-2007 09:53 PM
