#1 |
1/4" usb board underlayment in bathrooms
Is it a goord idea to waterproof the usb board before i vinyl it....i bathroom i have done i noticed mold when i had to replace a peel in stick area....i think it would be a good idea
#2 |
Hulk,
First of all, get rid of absolutely all mold and fix those leaks that caused the mold. Next, OSB is not a good underlayment for damp locations. It swells and wicks moisture. I suggest you tear it out and use a good plywood specifically suited for use as underlay. Regular plywood has voids within the layers that can crush under the weight of a heel. Any good lumberyard should be able to provide the right material. Lastly, make sure the underlay is secure and smooth. Vinyl doesn't hide flaws, it magnifys them. |
#3 |
agreed.
| Display Modes | |
| Installing backerboard - replace particle board? | salvop | Flooring | 10 | 04-29-2011 11:32 PM |
| Backer board vs. plywood for tile underlayment | allpraisebob | Flooring | 4 | 01-07-2007 08:44 PM |
| Installing deck ledger board over foam board? | RickT | Building & Construction | 5 | 11-06-2006 11:50 PM |
| Ruud a/c control board replacement ? | kourso | HVAC | 1 | 07-20-2006 10:33 PM |
| Particle board underlayment help | diynut | Flooring | 5 | 03-07-2006 06:22 AM |
