1/4" Substrate For Vinyl Flooring? Recommendations? - Flooring - DIY Chatroom Home Improvement Forum
Old 05-14-2012, 12:00 PM   #1
Rewards Points: 262
1/4" Substrate for vinyl flooring? Recommendations?
We are in the progress of renovating our living room, which was slab on grade. We put down the Platon system (HDPE dimpled membrane) with a layer of 1/2" plywood on top and screwed it all into the slab with 2 1/2" tapcon screws at 12" O.C. We were planning on installing a vinyl flooring of some type, but were told we needed another 1/4" underlayment which would be smoother than the plywood, would be stapled at 3" O.C., and would not telegraph seams. Can I just use any 1/4" sanded hardwood plywood for this? Preferably I can get this at Home depot. Any suggestions? Thanks in advance.
tpagel is offline   Reply With Quote
Old 05-14-2012, 12:11 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 126
Look for underlayment grade plywood. The others may have voids in the plys which can collapse.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 05-14-2012, 07:33 PM   #3
Too Short? Cut it Again!
Cork would do the trick and give the floor some resiliency. You have enough stability there.
Old 05-14-2012, 08:22 PM   #4
Rewards Points: 126
Cork underlayment under vinyl would probably violate the warranty. I would check before you use it.
Old 05-14-2012, 08:27 PM   #5
Rewards Points: 13,750
Cork would be fine for something like laminite but not for vinly flooring.
1/4 Subfloor rated plywood is the way to go.
Never louon!
Making some wood work using 2 1/4" hardwood flooring planks htabbas Carpentry 3 12-03-2011 08:30 AM
The 3/4" hardwood flooring I bought is 1/4" taller than the nosing endeavour Flooring 1 12-03-2010 06:42 AM
need flooring recommendations for an 1890s 4-sqaure brick house Williamstown Flooring 0 02-01-2010 08:44 AM
Need Cost Recommendations on Engineered Oak Flooring Mommied4 Flooring 4 01-20-2010 06:17 AM
Basement Flooring Recommendations wtdedula Flooring 2 10-19-2009 10:48 AM
