1/4 Inch Gap At The Transition? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-28-2010, 09:32 PM   #1
1/4 inch gap at the transition?
Hi all, I have a question here about adding wood "T" saddles to transition from our wood floors (in the den) to our newly tiled kitchen. I had someone come in to "mud" the kitchen before I installed porcelain tile. The "mud" guy did a great job and the tile went down very nicely. Here is the problem, he ran the mud right up to my 3/4 inch wood flooring that's right next to our kitchen.
Shouldnt there be a 1/4 inch gap at the transition? I guess I could "rip" the T saddle flat. However, will no gap cause a future problem since the wood flooring that's running parallel to the tile has no gaps to expand? The transition opening with the wood strips (running parallel) is 4 feet wide. Any suggestions would be much appreciated. Thanks
zman22 is offline   Reply With Quote
Old 03-29-2010, 09:15 AM   #2
Tileguy
JazMan's Avatar
Rewards Points: 288
You're right, there should be an expansion space between the wood and tiles. The "T" is usually close to 1/2" wide, so you need to start with about 1" gap. The T is nailed to the floor, leaving space on both sides.
Jaz
240V 2 pole 1/2 inch GE breakers? Isaac-1 Electrical 12 02-09-2010 12:21 PM
14 inch tank on a 12 inch bowl? jimmybush Plumbing 2 10-02-2009 02:13 PM
1 1/2 inch zone valve - can't find BOUTYM HVAC 2 11-20-2008 11:03 AM
Water Heater 1/2 inch pipes tke402 Plumbing 7 10-04-2008 12:19 PM
new 41/4 inch tile does not match old 41/4 inch tile sweet123 Flooring 2 12-27-2007 09:53 PM
