1/4" Or 1/2" Cement Board? - Flooring - DIY Chatroom Home Improvement Forum
Old 09-13-2007, 09:13 PM   #1
kemerick's Avatar
Rewards Points: 87
1/4" or 1/2" cement board?
For my kitchen remodel, in preperation for laying 20" ceramic tiles; I fixed my squeeky floor planks which lay on joints (16" spread) and then sheeted T&G 3/4" plywood. I used 3" screws and Liquid Nails subfloor glue.
I have a couple very minor soft spots that my wife does not even notice. I am however concerned and contemplating 1/4" or 1/2" Hardibacker sheets. I know Hardibacker is not structural, but I am thinking 1/2" would be the better choice.
Should I use 1/2"?
Should I use roofing paper on the subfloor before I lay the first layer of thin set for the Hardibacker... or is that too anal?
kemerick is offline   Reply With Quote
Old 09-13-2007, 11:02 PM   #2
jproffer's Avatar
Rewards Points: 716
Like you said, it really makes no difference. Use whichever one suits your needs (the adjacent floor heights, etc). No need for tar paper, just:
Plywood
Thinset (very important)
Hardi (or whatever type concrete you're using)
Thinset
Tile
(in order of use, obviously, not top to bottom)
jproffer is offline   Reply With Quote
Old 09-14-2007, 05:29 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Either thickness cement board you end up using, you want to consider a "ditra"-like membrane over it.
Links:
http://www.johnbridge.com/ceramic_tile_floors_ditra.htm
http://www.schluter.com/6_1_ditra.aspx
- Build Well -
Old 09-14-2007, 06:49 AM   #4
kemerick's Avatar
Rewards Points: 87
Interesting... I have never heard of the Ditra product but it looks promising. Thanks to both of you for the information.
My constant project is my home, my play time is usually spent on my CNC router.
Old 09-14-2007, 11:42 AM   #5
Tileguy
JazMan's Avatar
Rewards Points: 412
If you go with a product like Ditra, it's instead of any CBU. No Hardi. Ditra is not only much easier to install, but is a better surface to install tiles to. It does cost more however.
Jaz
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
1/4" usb board underlayment in bathrooms thehulk1978 Flooring 3 12-05-2006 04:16 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
Bathroom cement board dah General DIY Discussions 2 07-11-2006 06:25 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
