-   -   1/4" or 1/2" cement board? (http://www.diychatroom.com/f5/1-4-1-2-cement-board-11532/)
kemerick 09-13-2007 09:13 PM
For my kitchen remodel, in preperation for laying 20" ceramic tiles; I fixed my squeeky floor planks which lay on joints (16" spread) and then sheeted T&G 3/4" plywood. I used 3" screws and Liquid Nails subfloor glue.
I have a couple very minor soft spots that my wife does not even notice. I am however concerned and contemplating 1/4" or 1/2" Hardibacker sheets. I know Hardibacker is not structural, but I am thinking 1/2" would be the better choice.
Should I use 1/2"?
Should I use roofing paper on the subfloor before I lay the first layer of thin set for the Hardibacker... or is that too anal?
jproffer 09-13-2007 11:02 PM
Like you said, it really makes no difference. Use whichever one suits your needs (the adjacent floor heights, etc). No need for tar paper, just:
Plywood
Thinset (very important)
Hardi (or whatever type concrete you're using)
Thinset
Tile
(in order of use, obviously, not top to bottom)
AtlanticWBConst. 09-14-2007 05:29 AM
Either thickness cement board you end up using, you want to consider a "ditra"-like membrane over it.
Links:
http://www.johnbridge.com/ceramic_tile_floors_ditra.htm
http://www.schluter.com/6_1_ditra.aspx
kemerick 09-14-2007 06:49 AM
Interesting... I have never heard of the Ditra product but it looks promising. Thanks to both of you for the information.
JazMan 09-14-2007 11:42 AM
If you go with a product like Ditra, it's instead of any CBU. No Hardi. Ditra is not only much easier to install, but is a better surface to install tiles to. It does cost more however.
Jaz
